Compression/Leak-down testing procedure?
		I may try to compression/leak-down test the miata this weekend.  I’ve got the general idea but tried to look online to get more detailed “step-by-step” instructions.  Didn’t have much luck finding concise instructions.  If anyone knows of a good reference could you please point me to it?
In general, this is my take…
First run the engine to normal operating temperature. Then do the following tests.
For leak-down test, use the following: http://www.harborfreight.com/cylinde...ter-94190.html
Remove all the spark plugs.
Put car in neutral to allow crank to rotate freely.
Rotate #1 piston to TDC of the compression stroke.
Put the car in gear to prevent the compressed air from rotating the crankshaft.
Connect leak-down tester to cylinder.  Apply 100 psi to the regulator side of the tester.  Read the % leakage on the second gauge of the tester.
Repeat above for each cylinder rotating each to TDC of the compression strike.
Easy enough to stick a long wire in the spark plug hole to verify that the piston is at the top of the stroke but since the piston will be at the top of the stroke twice per cycle, how do I know when its at the top of the compression stroke?
Does it matter how or which way I rotate the crankshaft?
For compression test, use the following: http://www.harborfreight.com/flex-dr...ter-92697.html
Spark Plugs still removed from previous leak-down test.
Connect compression tester to #1 cylinder.
Press the gas petal all the way down and crank the engine at least eight revolutions.
Observe and record the maximum reading from the tester gauge while cranking the engine.
Release pressure from the tester/cylinder and remove the tester from the cylinder.
Repeat above for each of the remaining cylinders.
I think I read somewhere that I need to disconnect the coil or it’ll get damaged by cranking the engine without being connected to plugs.  Is this correct and/or is there an easier method?
TIA for any suggestions/advice.
