I bought a set of wheels from a member off his NA Miata with the intent to use them on our Mini. The bolt pattern is correct as is the offset but I didn't bother to check the bolt hole sizes. It turns out the wheel bolts on the Mini are a larger diameter than the Miata. Does anyone know a machine shop that could bore the bolt holes out to a slightly larger size? I'm guessing it's probably only a few mm.
