Originally Posted by
mr brg
Did you fill the radiator with distilled water?
Yes, always distilled.
Is the thermostat opening all the way?
Not sure, but I think so. Car runs normal 80% of the time, even in this brutal heat.
I think you can test resistance on the fan motor and compare it to a working fan. (I have a spare in the garage we can compare with)
Can I use a volt/ohm meter for this one? I'm a n00b in this dept.
How much resistance on the CLT sensor at cold 100*f and 210*f?
Where is your belly pan?
Stock belly pan is on the car, it's seen better days, but structurally it's sound.
What are the chances of a leaky hose?
Hoses are not very old, pretty sure all the water is still in the car.
Did you possibly warp the head with it pegged hot? Its time for a leak-down test after what you've done.
I don't think it got that bad, I think I saved it in time. It wasn't pegged, I exaggerated. It was maybe 90%. I'll keep an eye out for oil in the coolant of the other way around.
How much pressure is the water pump making?
No idea, but I have a TB kit in the garage with a new water pump. Maybe it's time for the dreaded TB job.
It could still be the thermostat because it's much easier to cool the car when it's moving, making traffic require more flow through the thermostat.
The car stays cool 80% of the time, only when it gets below 20mph for an extended amount of time.
