My CG-Lock recently died. I know another Miataphile who's ready to by one as well, so I thought I'd post and see if there are enough of us to go in on a group buy. Reply or PM if interested.
How did it die? Mine fell apart and I emailed the owner, he mailed me a new one and I mailed my old one back.
I have one for sale: $30
I got one, it exploded the first time I used it, I sent it back and got a replacement, for free also. Then the replacement died within 2 events also, so I gave up. Have any of you gotten much use out of yours?
I should mention that they were Rallycross events both times, so there was a lot of jostling/bumps/jolts, but I was still hoping it would at least temporarily satisfy my harness craving, haha.
End threadjack, sorry.
I've had mine since 2006. I do about 40 events per year, so it has a couple hundred events under its belt (pun intended). No major problems, but it is finally starting to slip on occasion. I guess that is acceptable after so much use.
Go to your local Babys-R-Us and buy one of these... ($2-$3 IIRC)
http://www.amazon.com/Evenflo-Lockin.../dp/B000056J8F
Works just as well just harder to adjust properly.
The "engagement thingy" snapped off. The pin is damaged, so snapping it back on doesn't disengage the spring. Now only functional as a paperweight.
This was it's 4th year of use, at 12 to 15 AutoX events per year. That seemed like a fair bang for the buck, but I'll contact them to see if they'll replace. Thanks for the suggestion!
