cooling issues-fans are confusing me!!! plz help
Ok, so I have a 94 miata and have been having cooling problems this summer.
Problem is when I have the a/c on the car will overheat at stops and/or while even going as slow as 40mph. Good thing I drive all highway to work everyday!
no fans come on with the a/c off and the car is overheating. When I turn on the a/c regardless if the car is cold or overheating the drivers side fan comes on(which is the cooling fan correct?). With the a/c on the drivers side fan come on and off with the compressor. I would think that the condenser fan should come on right?
So I did the jumper trick with the diagnostic jumer box and with the key on the drivers side fan comes on. Not the passenger side.
So I think I have a couple issues here.
1. The cooling fan(drivers side right?) doesn't come on when the car overheats but when the a/c is on.
2. the condenser fan(passengers side) should come on with the a/c clutch. Not the drivers side.
I know the condenser fan workings because I took it out and hooked it up to 12v power and the motor came on. I took the thermo switch off and grounded it with no luck. I also grounded the blue/white ground wire coming out of the a/c fan relay and not luck there. It is supposed to run to the pcm and the pcm should ground it to turn on the a/c fan.
I tried to type this up as best I can. If something doesn't make sense plz let me know.
Thanks for all suggestions.
