What is PCM stands in the shop manual? Is it = ECU?
The shop manual also refers PCM terminal 1U. Do I have to remove the carpet behind the passenger seat and carpet to get to the ECU to find terminal 1U?
Yes the power-train control module (PCM) is the engine control unit (ECU) ... The book should have the diagram showing the 1U terminal after u get to the ECU..
ECU stands for engine control unit and PCM stands for powertrain control module. Pretty much PCM=ECU.
I'm not sure about finding 1U.
