;)Thinking of going Mobil 5w-30 or 0w-30 if i can find it.... Any one have opinions before I get it changed? Also gonna get an air / oil filter.
Car has 80xxx miles by the way.
Updates:
So I'm still really considering mobil 0w-30... and then for my second switch as it gets warm again to 10w-30, or perhaps just using 5w. though I have a few points... Is the only reason to switch to synthetic because it lasts a longer duration than "dino" (which I'm assuming is regular oil that the manual suggests) and that it might save money in since you only have to replace it at 7500 miles instead of 3000? Or is there a benefit to running high quality oil as I previously thought?
Additionally, I will be changing the oil / air filters and the spark plugs. I found a forum page about using the Mobil #110 instead of the suggested #108 since it was larger and still fit in place. The air filter will be what is suggested. And the spark plugs I'm considering going with autolite platinum's, even though it suggests copper, I have seen a lot of people suggesting these since they are higher performance and still very cheap.
And finally, I will be doing all of this myself, I need the experience in cars, and I've be told lovely stories about how easy the oil is to change in a Miata. If it's as easy as the coolant flush I just recently did, I should have no problem at all.
Thanks for all of your thoughts I am still debating between 0w, 5w, 10w, and to just keep "dino" because my car is used to it. There's a lot of different opinions out there.
