Ok I started hearing a clunking noise that sounded like it was coming from the front end about two weeks ago. The noise can be heard best at slow speed when running over rough pavement or making a right hand turn, and appears to be coming from the front passenger wheel. I can not recreate the noise with the car stationary and have tried just about every method I can think of. In all honesty it sounds like a loose wheel, don't ask how I know this, but I have double and triple checked all four. I also had an alignment done and it made no difference and they didn't notice anything either. Yesterday I had the radio off while driving home and I could hear the noise while driving on the freeway around 65-70mph. The noise was bad enough that I decided it was not a good idea to drive the car anymore until I locate the problem.
I have had the car on the lift numerous times and can not find anything loose and I have already checked the front ball joints, tie rods and bushings, but since the noise is not a single clunk I didn't really think that was it. I have also checked the motor mounts, shocks, springs, chassis bracing and drive shaft and all are fine. Hell I even checked the subframe bolts! There is a possibility it is the front sway bar, but everything is tight and the mounts are not cracked and I'm also running the Racing Beat sway bar brace. I'm at a loss so I looking for suggestions from the peanut gallery. Anyone have any ideas?
BTW the car has around 87k miles on it.
Edit: I should add I have also check the exhaust system and it has plenty of clearance and makes no noise when I move it around.
