Cat delete, O2 Sensor CEL fix
Hey everyone!
I've spent a couple of hours reading through threads about how to fix the CEL associated with removing the catylatic coverter. Please don't preach to me about pollution. This is a steet legal, track car and I'm proud of my carbon footprint.
I have an aftermarket header/exhaust system that has the cat deleted. The second O2 sensor has been simply zip tied to the frame as the there is no bung welded into the pipe. I'm currently throwing a code: P0140 - 02 Sensor Circuit No Activity Detected. This code should not have any influence on the tuning of the ECU, as it only monitors the efficiency of the cat.
From what I've read, I have several options but I'm not sure what is best:
1. Weld in a bung and install an O2 sensor spacer or mini-cat spacer. IF this works, it would probably be the most realiable fix as there are no electronics involved. How successful have you drivers been with this fix after removing the cat? Is it worth paying the extra $$ to get the mini-cat? Any recommendations?
2. Various O2 sensor emulators/simulators/eliminators. I've seen everything from DIY circuit boards to semi-professionally produced products. It seems that the big companies get pressured by the EPA not to sell these products. I'm not clear on a couple of things. If I use an O2 simulator, is the old O2 sensor removed and the box wired into it's place? Any luck with the DIY boards? Feedback and recommendations are appreciated.
Jimmy
1996 Miata, 5spd
