Our '02 with 78,000 miles smells like antifreeze.
I just went over the car and I am not finding any signs of leaks.... :confused:
I'm thinking it is the water pump I took the belt off and spun the water-pump and found no excessive play or any telltale signs it is leaking but since 90% of the water-pump is behind the plastic covers I still am thinking it is the culprit.
My local vato-zone didn't have a pressure tested available currently but I figure I'll pressure test the system to see if I can find where the smell is coming from. Is it a safe assumption that a seeping water-pump would leak while using the pressure tester??
May also run it up to the Fiat dealer and see what they will give us on trade towards an Abarth. ;)
