Hey guys, my brother has a Mazda 6 that's in need of some air conditioner work. Anyone know a shop they'd recommend in the north Dallas/Plano/Frisco area?
Regards,
Piff
Regards,
Piff
Does he know what he needs?
I topped off the refrigerant in three cars this weekend. It was easier than I thought it would be. Walmart $17 for the gauge/hose, $5 for a can of oil, $9 each for cans for R134a. I used 3 cans. Use goggles and heavy gloves. The instructions come with the gauge/hose. Three cars blowing cold air now.
good luck with Graham Auto Air near SMU
214-361-5583
One of his hoses apparently has a leak at the coupling. He's thinking about replacing the hose himself, but will need to get it evacuated by a pro. But he cant be sure thats the only leak. Can't a pro shop check for leaks by pulling a vacuum on the system and watching for pressure variations?
Regards.
Technicare in Dallas does very good work. He has a sensor that will detect even the smallest leaks throught the system. I was having a problem with my Dodge Ram several years ago and no one could figure out why it was loosing refrigerant. He was able to determine the seal on the compressor was bad and the refrigerant was leaking around the pully shaft. He showed me how it worked and how sensitive it is.
Technicare Auto Specialists
11054 Shady Trail #301
Dallas, TX 75229
(214) 352-0499
technicareauto.com
2nd for Paul at Technicare
