Feeler: NC Hardtop w/ dolly and cover
I picked this up since they are pretty hard to come by, but I'm already realizing that I will use it about as much as my Jeep hardtop and the pool table I HAD to have when I was 30...
The color is Copper Red Mica with the standard grey headliner. One small chip on the leading edge, paint is excellent and a very pretty color. I have an excellent paint guy if you are interested in having it matched to your car, willing to help arrange that for a buyer. It actually looks pretty good on a Brilliant Black or a Galaxy Grey.
Includes:
- Frankenstein Bolts for NC
- Defroster Harness (stoopid expensive!)
- Rolling storage dolly (vertical) and slip cover for top
- Side latches and center latch (you will need to order side strikers for the side latches from Mazda, I can get them for $75/each, but the top is plenty secure without them, just not as rigid. You'd need them for a track day)
The top weighs around 40 lbs and is the easiest HT I've ever dealt with. I have no problem installing and removing by myself, and two petite granny's could easily manage it. Seals quite well, is quiet on the highway and does not leak AT ALL. Makes the AC/Heat work better. Back window is much bigger than soft top and curves around the sides. The NC looks better with a HT than ANY other version of the Miata.
$2100 delivered within 100 miles of DeSoto (almost-nearby-home of the Superconducting Supercollider!)
Edit: I'll get a better picture tomorrow with the car removed from its space-saving upside-down ceiling hanger. stoopid iFone!
