So I have finally gotten around to swapping out the carpet on the 99. I really don't have any desire to pull the dash out and I've read where a lot of people have just split the carpet under the dash to get it out so thought I'd go with that approach. My old NA provided easy access by removing the radio and cubby but the NB isn't so simple with the airbag switch and HVAC controls located at the bottom of the panel.
First I need to remove the center radio surround trim panel but it looks really thin/weak at the bottom corners. The clips weren't popping loose and I was afraid to pull too hard. Is there a trick for popping this off without breaking it? can't really get a screwdriver under it to help pry.
Also, I'm all ears for any suggestions cutting out the carpet... what best to cut it with, how to make sure I don't "accidentally" cut any wiring running under the carpet, etc...
I did do a decent bit of searching but the best I could find was people saying to cut it out, but no real info on the best way to go about doing it.
TIA,
Keith
