Date Item Mileage
3/9/2011 bulk oil, filter, gasket, rotate tires, new battery, vapor hoses, spark plugs (all at hiley mazda) 55631 3/9/2011 Passed safety/emissions inspection 55632 6/9/2011 Timing belt, tensioner spring, water pump, water pump gasket, thermostat, thermo gasket, mazda coolant (green), crank oil seal, pump inlet gasket, camshaft sensor (all at hiley mazda) 56733 3/26/2012 Passed safety/emissions inspection 58193 7/11/2012 alignment and inspection, tires have 6,000 miles 58960
This is what I got as far as maintenance from the previous owner, he didn't have car very long, he bought it with 52k miles in April of 2010.
Its an 02 LS 6 speed.
Just hit 59100 miles, and changed the rear differential fluid to redline 75w90 today. Took a little less than a quart before it started coming out of the fill hole. Manual says its capacity is 1.1 qt, maybe some built up gunk inside? Glad I changed it cause the old stuff looked like chocolate milk. Little bit of sludge on the magnetic drain plug, but didn't see any large metal chunks.
Tomorrow planning on doing 2 quarts of redline mt-90 in the transmission, inner and outer shift boots, and racing beat dual muffler (shout out to william at track dog!). If I have time, will also be doing stoptech front pads and centric rotors (thanks tire rack), rotating tires, and shell rotella t 5w-40 synthetic oil change. Need a suggestion for oil filter, I assume mazda dealer is my best bet?
Am I forgetting anything else at 60k?
Thanks guys.
