Hi all! I received some new coil-overs for my NA as a gift. Changing out the rear has been no problem, but I have a big problem on the front. When I attempted to loosen (not remove) the nut holding the shock to the tophat (middle bolt) it broke off the nut and bolt. I can't seem to get the strut spring clamp/s mounted because of limited space in the wheel well.
Do any of you have any suggestions on how I can safely remove the strut\spring?
Thanks!!
Justin
