I've already asked this before but it looks like my previous post for months ago got deleted. What's the trick to go lower for the rear shocks?
Not sure what you mean by trick? You just shorten the shock bodies as much as you can and lower the spring perch. If you instead you want your suspension to work... Read a thread on miata.net called "tein flex rough ride." You need to measure available droop etc to find the right settings.
Long, but worth the read: http://forum.miata.net/vb/showthread.php?t=266038
you'll need to pre-load rear springs ... roughly an inch. other than that, it's pretty straight forward. unbolt the upper control arm to make your life easier :)
Thanks guys
