Whoa!  My Azenis are worn out!
		Must be something wrong with my car.  My rear Azenis are nearly bald!  :wink:
I ordered some more and can get them installed Saturday.  I think I can get enough miles to have them worn in by Thursday.   Should I run the Azenis that are bald or run new Azenis?
I think the wear pattern was a bit odd.  They are worn primarily in the center.  I've been doing a lot of over-steer turns latley.   :D  The driver rear was more worn than the passenger rear.  The driver's rear might have been cupped.  I'm not an expert on tire wear but it seems a bit lower in the center.  What is the likely cause of this wear?
I've been bad and haven't checked my tire pressures as I should but had them at about 30 psi.  Tire size is 195/60/14.
		Re: Whoa!  My Azenis are worn out!
 I'd go with the bald ones personally!  8)  Could be fun! YAzenisMV.
