I'm trying to remove the aftermarket hub to install the new clock spring but but it won't budge....any help would be appreciated
leave the steering wheel on the hub, loosen the nut that holds the hub a little bit and pull the steering wheel?
Go rent a puller from auto zone if the above suggestion doesnt work. A little penetrant soaking in for a couple hours might help too.
Worked perfectly...thanks a BUNCH
