1999 Miata, "fully loaded" with Torsen LSD, leather, power windows, doors, and aftermarket alarm (pics below). Passenger window works great, Driver's window could use a cleaning but works fine. AC blows strong and cold yada yada yada. I do add a bit of oil every couple of months. The car is just over 160k miles, but the engine was rebuilt by John Day ~37,000 miles ago. During the rebuild a lot of other parts were replaced as well (see below). Car runs strong: Enhanced Megasquirt 2 built by Reverant (user on Miataturbo.net), 131 whp & 115 wtrq on a Mustang Dyno (I'm told this equates to ~145 whp & 127 wtrq on a Dynojet fwiw, all I know is throttle response is crisp and the car pulls harder than before). I've had the car since August of 2010. I've taken the car to the track four times, the rest of the time it was my daily driver until April 2012 (finally got a car with a back seat to be my daily).
During the rebuild, the following work was done:
Rebuilt engine (new parts):
rings
bearings
timing belt guide bearings
all belts, gaskets, and hoses
exhaust valve guides
Rebuilt engine (machine work):
balanced reciprocating and rotating assembly
resurfaced flywheel
valve job
Replaced when the engine was rebuilt:
Hondata intake gasket
engine mounts
O2 sensors
cam sensor
coil pack
fuel pump
rear wheel bearings
Exedy Organic clutch
rear diff bushings (Mazdaspeed)
fuel filter
injectors cleaned
Fluids:
brake fluid – RBF 600
oil – Mobile 1 5w30
transmission - Motul
rear end - Red Line
Additional Upgrades:
TR Motorsport 15x7 with 195/50/15 Bridgestone Potenza RE-11 (installed on 9/28/12, less than 1k miles on them)
Xida Clubsports with 550/350 springs + helper springs w/ NB Top Hats ($2160 coilovers)
Enhanced Megasquirt 2 with MAP sensor built by Reverant, (includes tuning cable)
GM IAT Sensor
MTX-L wideband
RB 4-1 Header w/ TDR heat shield
Roadster Sport Catted Midpipe
Roadster Sport 3 Muffler (Includes removable sound baffle)
Koyo 37mm Radiator (installed June 2012) with New overflow tank (2 years old)
Hawk DTC-30 pads front and rear (Installed by TDR January 2013)
Stainless steel brake lines (Installed by TDR January 2013)
New Brake Master Cylinder (Installed by TDR January 2013)
Hard Dog Double Diagonal Sport Roll bar & Hard Dog Harness Bar (5 point harness mounts included, belts not included)
Kenwood cd player with iPod hookup running the Bose Amp/speakers (stock unit died).
Foamectomied both seats (also have an extra cushion that is gutted for a bit more headroom at the track)
The car as is with the MegaSquirt, WB, and GM IAT is $8,500
Without the MegaSquirt, WB, and GM IAT is $7900
http://i1166.photobucket.com/albums/...B8C27B886C.jpg
http://i1166.photobucket.com/albums/...n/e6604cd5.jpg
http://i1166.photobucket.com/albums/...B8DFE79A66.jpg
http://i1166.photobucket.com/albums/...68DD714BB4.jpg
http://i1166.photobucket.com/albums/...n/ms2_dyno.jpg
