This is sort of for POS since we talked about it yesterday, but I wanted everyones ideas. I did a compression check on the engine today. 160-163 across the board dry, 190 in 1,3,and 4 210 in 2 wet. I think I put a bit more oil in number two so that might throw results huh? My car burns oil especially at autoXes when I close the throttle at high rpm. THe smoking has been brought to my attention even by others. Would these results seem to point towards rings or head? I will do a leakdown, but I am taking the car to the body shop tomorrow, so it will be a week or so for that.
BTW: I read in the tester instructions, slow build up to pressure can indicate bad rings. What is slow build up? The way mine was, on the first stroke, 120-130 second 150 and third 160. Any thoughts on that? Thanks guys
