help! getting no sprark or fuel
So ive searched all around and have tried everything short of pulling the head back off. I was forced to essentially change the head gasket due to a spark plug and ezout breaking off. I removed the head and gave it to a friend who said they could extract the broken ezout and plug for me. I just got it back last week and proceded to insall it thurs on the 4th before going out of town til sunday. Sunday i finished the install/ double checking everything and went for first start. Cranks beautifully but has no spark or fuel. Ive checked all grounds and connections and have even moved some grounds around to double check good. I hear no fuel pump unless i jump f/p to ground. Removed cas and hand spun to see if i get a tach reading, nothing. Removed valve cover to triple check timing and even spun crank 180` then reset timing based on the crank notches tdc. Swapped conecters of coil packs to see if i possably got them backwards, (both are 4 prong, and plug into eachother the same, still dont know if its right)... yesterday was a furlough day so i messed with it alittle. Checked fuelpump relay under steering wheel. I can hear a click as long as the jumper from fp to gnd is in. What the heck should i do next. To get a proper diag will cost me alot that i dont have now that where in furlough status. Suggestions? Det cord?
What to do....
PS- started and ran like a champ before plug broke off/head came off.
