Upgrade shopping list? And random Questions? 97 1.8 to 99-00 1.8
My 97 has developed a rod knock so I'm planning to pickup a 99-00 motor. I'm looking to start a list of everything I will need to locate, may depend slightly on what all I get with the motor I buy. (Hopefully it comes mostly complete, but sometimes they don't come with coils/intakes or other misc parts.) Any tips on what to look at before I pickup this junkyard motor? I will try and check the endplay and look for oil leaks (if they haven't dried up) beyond that I just plan to check the head has the correct casting #s.
What are people using to control the VICS? Would like to keep the stock ECU for now if possible, would like to be able to get the car inspected with minimal hassle and until I turbo the car a stock ECU should be fine.
I've read the cam angle sensor is different but I can retrofit the one from my 97 what all is involved?
Are there any simple/cheap upgrades I should do while I have things apart?
Mill the head?
Swap intake cam for a exhaust one?
Adjustable cam gears?
New valve seals? Gaskets etc?
Thanks for any advice.
