1995 streetable track Miata for sale
Red 1995 Mazda Miata Hardtop with 83K miles for sale $6500. Fully streetable, licensed and inspected. Ran mostly in PCA Time Trial and DE events. Contact me by email directly at:
ex pv dallas guy at hotmail . com (remove all spaces, change “at” to “@”).
Selling this car simply because I’m too old to work on it, and don’t feel safe driving it anymore with big trucks. Pic here: http://www.dfwmiata.com/album.php?al...achmentid=6357
Car details below:
BODY AND SUSPENSION
• 4 point Hard Dog “Sport” roll bar with single diagonal; cross-brace for harness
• RCI “8000” race-seats with 5-pt access holes for both driver and passenger
• 5-point cam-lock style harness for both driver & passenger
• Momo “Tornado” steering wheel
• Wink 4 panel mirror
• Sway bars are Racing Beat 1 1/8” tubular front and 5/8” solid adjustable rear
• Two sets wheels 15” X 6.5” lightweight Rota “Circuit 8”, both with 205VR50-15 used Kumho XS
• Goodwin Racing Big Brake kit with 11” vented front rotors with Wilwood Dynalite 4-piston calipers; 10.75” solid rotors on rear with stock calipers. Hawk HP+ pads front, Hawk HP+ pads rear. New set of front HP+ pads included. Several ½ used sets included.
• Shocks are Koni Yellow “Sport” adjustable
• Adjustable coil-over conversion from Ground-Control with 500lb/in front and 325lb/in rear springs. Several other spring sets included.
• Extended front and rear shock mounts from FM
• Butterfly Chassis brace from FM—using rails only, center section off car but included.
• Hard-top installed; factory soft top in excellent condition included.
• Has factory front chin spoiler with ducting to front brakes. Copy of factory rear spoiler also.
• Car weighs 2360lbs
ENGINE AND DRIVETRAIN
Engine shortblock is rebuilt 1995 Miata done 3K miles ago. Machine work and assembly by Day Custom Engine in Richardson.
• 1999 Cylinder head with porting job by John Day at Day Custom Engine; factory 99 intake using 95 injectors, butterflies controlled by MSD 8969 Digital window switch
• 10:1 factory pistons from 2001 Miata
• Megasquirt PNP MM9495 Standalone ECU ; MAF removed converted to Speed-Density; setup for idle/crusing closed loop with wide-band O2 sensor. Custom tuned on Mustang chassis dyno (reads lower than Dynojet) by PRT Performance (Steve Kahn Tuning) in Lewisville. Corrected rear-wheel results were peak of 136hp/127lbft. Peak torque at 4300, 125lbft from 3850rpm to 121lbft@5200rpm.
• AEM UEGO Controller Wide Band sensor and Gauge; interfaces with Megasquirt
• Racing Beat 4to1 Stainless Steel Ceramic coated header
• Fizanda lightweight flywheel with ACT XT clutch.
• EnthuzaCar 2.5” Stainless Steel cat-back exhaust system with Magnaflow muffler single outle; tBorla muffler included, full SS 2.25” cat-back from Thermal Research also included.
• FM high-flow Cat; stock Cat included
• FM “racing” high capacity all aluminum radiator; stock radiator included
• MazdaSpeed short shift transmission shifter; stock shifter included.
• Torsen diff rear from 2001 Miata with 4.30 gears
MISC INCLUDED
• Car cover
• Mazda Shop Manual and Enthusiasts Shop Manual
• 1995 Miata factory ECU
• Bipes ACU 1.5
• Stock seats and seat belts; stock steering wheel
• Stock belly pan, all stock suspension parts and exhaust.
• Stock brake parts, all A/C parts, power steering parts (working when removed)
• Complete spare 5spd transmission; should be good (got with engine)
• Misc 99 engine parts, cambox cover, injector rails, etc
• Factory steel 14” wheels with tires.
• Extra used 205/50-15 tires: full set of RA1, 5 Azenis,
• Basically all my Miata stuff.
