Stabilizing small solder joints
Odd question here... I've got a wired controller I'm trying to fix for my dad. It's got an array of tiny wires soldered to a PC board, which is then snapped into an external case. Tiny wires run into a sheath and exit the external case through a grommet. So, a couple of the wires worked loose, then we opened it up and managed to break all the connections. It looks like a really easy fix - solder tiny wires back to board, put the thing back together, profit. However, it looks like I need a way to stabilize those solder joints so they don't work loose again. I'm thinking some kind of clear epoxy or something to immobilize the wires in relation to the board. If we can't fix it, a new controller will run about $100 - and I'm guessing it'll just break again in a similar manner.
Any thoughts?
