Battery and Check Engine Lights.
On the way home to Fort Worth from Marshall, the Battery and Check Engine lights came on as I was on the 20 west to 35W south overpass soon after I turned on the headlights. I figured the alternator finally gave up the ghost after only 397,000 miles. I turned off all electrical that wasn't essential, and made it home. I pulled codes, it came up clean but incomplete as I had pulled codes earlier. When I started the car to check alternator voltage, no warning lights.
Has anyone experienced anything similar, and if so, what was the final outcome? Is my alternator on its way out, or maybe a stuck relay or gauge cluster issue? Until today, I haven't seen the check engine light on except for start up, even when the code scanner showed the MIL to be on.
Thanks for any help.
