Power difference between 1.6 5sp and auto
I've heard there is a difference in power output in the NA 1.6 5speed motors and the motors that came with automatic transmissions.
That is, apart from a difference in transmission alone.
I found one webpage that indicated that the cam spec on the automatics had less duration and lift on one of the cams.
Anyone have power numbers from dynos of cars with similar build, between the manual and automatic transmission ?
Wonding how much horse power difference the I might expect if I swap the cam from a manual motor into the automatic motor.
Jay Johnson
