WTB: 15x7 or 15x7.5+ wheels for NA/NB
		Looking for an inexpensive set of wheels that will work for 205-225 tires. 15x7 or 7.5"(or wider), 4x100, no crazy-low offsets. Not going hellafrush, so style is not important to me but weight is. These are for autox. Don't care about color or scratches, but not interested in junk or badly bent wheels.
Obvious candidates are TRM's, 6UL's, enkei racing, Kosei, etc. There are plenty of other brands that would work, but most of the rotas and such seem to be >15 lbs, which is too heavy. Basically, if you've got the right size, I'll at least consider it. PM me a description, price and location.
Also have a set of Rota Group N wheels in 15x6.5 that I'd swap for wider, and a set of OEM 14" miata steelies with good tires, trim rings and caps that are also available for trade.
Don't be shy about offering wider than 7.5" if you've got 8" or 9", as I do eventually plan to go wider, so might just skip the in-between. Budget is flexible if a quality set is available, but ideally looking to spend $100-150.
