I have a 1992 standard miata that I have already replaced the clutch master and slave cylinder plus installed new steel flex line last May.
Every thing was working fine until now. Now when you push in the clutch , all the way to the floor, it sorda doesn't disengage first gear... However does kinda shift ok through the remaining gears.
When I press down the clutch.. All the way to the floor. The slave cylinder only moves the release lever 1/2 inch. It just doesn't seem like that's far enough. Am I wrong?
Also I checked the master clutch cylinder for fluid and it had changed from clear to a very dark silvery color .. Not sure why it changed color and there is no leaks.
I flushed the line with new dot 3 fluid. After four days sitting in my shop the fluid is changing color again.
What's going on? Do I need to replace master cylinder and slave again?
Do I need to drop the transmission and replace the clutch?
Plus what brand parts do you like. Perhaps I purchased cheep.
Master and slave purchase from napa. Clutch line extension from 949 racing.
Any help trouble shooting this thing would be appreciated
Thanks !
