prototypes are out testing!!
Hello all! I'm happy to announce that the first two prototypes of our soon to be released NB2 "ram air" scoop systems are installed and in the testing stage right now.
The first short runs around the block show the air intake temps are ONLY 5-7 degrees above ambient temperature! The first kit is installed with a stock NB2 airbox, the second has a Monsterflow intake(re: it will work with ANY intake you have, except a Randal).
The kit will install in about 2 to 3 hours with only a Dremel(tm) and a socket set. Minimal cutting of the car and some plastics is required, but easy to do.
We're writing up the instructions now(with pictures) and will have a first run of 10 (with a low group buy price)very soon!
Post up here if you are interested, pictures will follow.
JDSM.
P.S. Yes, it is a hand-made kit... It is not as "pro" as an expensive carbon fiber kit, but it is also very stealthy, so nobody sees it anyway!
