FS: Corbeau FX1-pro seat w/ side mounts, NC brackets
Selling a very-clean condition Corbeau FX1-pro microsuede race seat that is currently setup for an NC, but can be fit into an NA/NB or other make of car fairly easily. This is the black microsuede ( like alcantara) version with leather patches on the high-wear areas. Very comfortable, good fit for 30-36 waist, but you'd want to test fit since everyone sits a little different. Reasonable as a DD seat if you set the rake where you need it. With the side mounts and the lower pad removed and a towel for padding I was able to pass a broomstick test in my NC with oem roll hoops. (5'9")
http://www.corbeau.com/products/fixe...seats/fx1_pro/
All of the pads attach with velcro, has holes for the submarine strap and shoulder/lap belt harness. I've added a blood pressure cuff behind the back pad to create adjustable lumbar support. Works great and the adjuster bulb fits alongside the seat. Easily removed. Works with oem 3-point belt too. I am including an NC seatbelt receiver that bolts to the side. The sensor plugs into the oem harness, and a resistor will turn-off the airbag light.
I currently have MER side brackets mounted to the seat, and a custom-made NC mounts attached to them to bolt it to oem location for drivers side. The seat also has bottom mounts and a back brace mount. I shaved the fiberglass "feet" from the bottom to let the seat sit lower, but the threaded inserts are still in there for bottom mounts. The MER bracket has several mounting holes to get the right height and rake.
I bought the seat new about 2 years ago and only had it in the car for about 6 months. Put it in/out a few times for track days, but has spent most of its time under a blanket in my guest room. No fading, so spills/stains/rips. These sell for $399 new, seat-only.
I am asking $350 for the complete seat/MER side mounts/lumbar/NC brackets setup, or $275 for the seat-only. I will sell the MER mounts with or without the NC brackets for $100 separately.
http://www.corbeau.com/product_image...-29501-F-L.jpg
