At first I installed it and it wouldn't start my car because it wasn't getting an RPM signal so I sent it back to diyautotune to get it fixed.
When I got it back I hooked it up and it started WOOHOO! but then my car sounded like a lawnmower. checked plugs and they were kind of dirty but fine. then I checked to see if all my injectors were firing with a stethoscope. Turns out Cyl 4 wasn't clicking like the others. Left it there for a few days and started it up again. A MIRACLE all 4 injectors were working so I guess that wasn't the MSPNP fault. Replaced the fuel filter and put in my new injectors anyways.
So the entire time i was doing this I couldn't get my AFR numbers to match between the gauge and tunerstudio so i couldn't use VEAL to tune it or it would give me an awful idle.
So Tonight as i write this my car is "running" on a base map.
both outputs set to innovate fault 0v= 7.35 and 5v= 22.39 my gauge will read 13-14 at idle and 8-9 on tunerstudio. Got the LC-2 Grounded at the ECU ground point at the front of the engine and my gauge ground is tapped into that. Tried both the default lc-1/lc-2 setting and custom linear wideband setting in tunerstudio with no luck. Pretty sure i've played with all the settings regarding AFR in tunerstudio and LM Programmer. I Tried using 0v=10 and 5v=20 no luck either.
I'm pretty sure everything is wired correctly but at this point it looks like I'm going to have to undo all the wiring get some new wires and do it again unless someone has some ideas or some local mspnp expert will come help me fix it :( or i can try and limp it to you if you live close by
no autox for me this weekend i guess :(
