Looking for a good used aluminum radiator for an NA. Also looking for OEM or after market fans, silicon radiator hoses, a cooling panel and a factory belly pan.
Let me know if you have any of these for sale.
Thanks.
Thanks.
Does the NB radiator fit? I have an oem nb in good shape...
I have a newish aftermarket slim fan and a good OEM fan too. The OEM had the wires cut close to the motor, so would need a little soldering work. You can have the OEM for free. You can check out the slim fan and maybe we can work a deal on that trim panel if you like it.
The slim is on the 90 right now, so I guess its got the right mounting stuff. The OEM is driver's side.
I have almost all of what u need
Got the radiator, fans and hoses. I still need a cooling panel and a factory belly pan.
Curious what you mean by "cooling panel."
Belly pans are ~$60 from Mazda brand new. Seems like the way to go to me.
Got my new bellypan from TDR
Gotcha'. On my track car I just fabbed one out of ABS using a TDR unit for a pattern. I'd happily offer up either for a pattern, but it's a loooong way from Plano to Granbury.
