This is an incredible deal. The owner is relocating and cannot take the car. No expense was spared. This car was built to track and last. Contact me for the owner's info.
Photos
https://www.dropbox.com/sc/1byvovb0m...jrTB-P7V499T7a
2005 BMW E46 M3 Coupe Track Car
This silver gray metallic 2005 BMW M3 Coupe includes over $28,000 worth of high value, aftermarket PARTS (does not include installation costs!) allowing it to deliver 344HPW at the wheels, 257lbs. of torque and corner like crazy!!!
Engine/Performance:
Super Sprint V1 Stepped Headers w/ Resonators
Epic Motorsports Alpha-N Tune (See Dyno Graph)
Bimmerworld Street/Track Axle Back Exhaust (Muffler)
Bimmerworld/C&R Racing Oil Cooler
Megan Racing Section 2 Mid-Pipe
Rogue Engineering Underdrive Pulley Kit
Fuel Injectors Cleaned and Balanced (March 2014)
Intake:
Evolve Automotive Carbon Fiber CSL Air Box ($4,000+ Upgrade Alone!!!)
Extra Evolve Automotive Air Filter
aFe BMW E46 Magnum Force Intake Kit; Stage 2 (Not Installed, but included)
Suspension:
AST 4200 Internal Reservoir Dual Adjustable (Rebound & Compression) Suspension w/ Hyperco 750# and Swift 616# Springs; Vorshlag Camber Plates; Vorshlag Shock Reinforcing Plates;
Hotchkiss 22826 Sport Front & Rear Sway Bar Set
Bimmerworld Sub-Frame Chassis Reinforcing Kit
Powerflex Rear Subframe Mount Kit - High Durometer
Powerflex RTAB
Powerflex Front Control Arm Bushing and Housing Kit
Ground Control Premium Adjustable Rear Lower Control Arms
Rear Adjustable Length Sway Bar Endlinks
Transmission:
Clutch Masters Stage 3 Kevlar Clutch (Installed April 2014)
JB Racing Aluminum Lightweight Flywheel (Installed April 2014)
Auto-Solutions Short Shift Kit
Bimmerworld Reinforced Transmission Mounts
Aero/Weight:
APR GTC-300 Adjustable Carbon Fiber Rear Wing w/ Side Plates and Carbon Fiber Gurney Flap
Carbon Fiber Sunroof Delete
Rear CSL Style Diffuser (Not Installed, but included)
Brakes:
Bimmerworld Carbon Fiber Brake Ducts
Bimmerworld Brake Cooling Kit
Turner Caliper Bushing Upgrade Kit
Stainless Steel Brake Lines
(2) Sets of New in the Box HTC-10 Pads (Front)
(1) Set of New in the Box DTC-60 Pads (Front)
(1) Set of New in the Box DTC-70 Pads (Front)
Competition Package Caliper Brackets & Replacement Calipers (Used) for all four wheels (Not Installed, but included)
Wheels/Tires:
OEM 19” Wheels
(3) Sets (i.e. 12 Wheels) of D-Force Wheels: (2) 18” x 10”; (1) 18” x 9.5”
(2) 20mm Wheel Spacer Sets (i.e. 4 Spacers)
12mm Wheel Spacer Set (i.e. 2 Spacers)
Bimmerworld Premium Race Bulletnose Wheel Studs (92mm)
(1) New Set (4 Tires) Hankook Z214 tires (18” for D-Force Wheels)
(2) Used Sets (8 Tires) Hankook Ventus V12 Evo tires (19” for OEM Wheels)
(2) Used Sets (8 Tires) Hankook Z214 tires (18” for D-Force Wheels)
(1) Used Set (4 Tires) BF Goodrich R1S Tires (18” for D-Force Wheels)
Note: All Tires are included in price, but if you don’t want them I can dispose of them.
Safety/Convenience:
RaceTech Seat 4009W; with Brackets, Mounts and Anti-Sub Belt
Cool Shirt Club System w/ Lg Shirt, 8' Hose and Mounting Tray Installed w/ Switch (Used 1 Time!)
Aftermarket Oil Temp, Oil Pressure, Water Temp Gauge Kit (Center Counsel Pro Install)
Mason Engineering Race Clutch Pedal
Quick Fit PRO 4 Point Harness – Driver Side (HANS Compatible)
Quick Fit 4 Point Harness – Passenger Side
Fire Extinguisher & Mount
Turner Metal Pedal Covers
Turner Tow Hook License Plate Bracket
Brand New Tow Straps (See Trailer Offer Below!)
Misc. OEM Parts that I have still.
Proactive Maintenance Replacements:
OEM Water Pump (Proactive Replacement)
Motorsport Thermostat (Proactive Replacement)
Guibo (Proactive Replacement)
Fuel Filter (Proactive Replacement)
Mileage: 99,540
History: 1 Previous “Street Only” owner for 77,941 miles. (Service Records Available); Weekend fun car/HPDE Car with current owner for 21,599 miles.
Price: $26,500
Serious inquiries only please.
NOT interested in “Part-ing Out” the car/Selling individual Modifications
Optional Item:
18’ x 83” Everlite Aluminum Trailer (Model: CH 82x18-7K) 7,000# GVWR Capacity (Dual 3500lb. Axles) w/ Tekonsha Prodigy RF Brake Controller – Brand New!!! I purchased this trailer a month before my job transfer and haven’t even towed the car on it!!!
I purchased the trailer for $5,448
Sell Price: $4,500 Try and find an 18’ new (or even used) aluminum trailer for that!!!
Track Turn-Key Special: Purchase Car & Trailer TOGETHER for $29,000!!!
