A question for 99 owners or someone who knows I guess.
You know the metal bar that goes over the oil filter that you have to remove to change the oil in a 99, what is that called?
It has two bolts that hold it in on top and one on the bottom.
How important is this to keep on, it seems easier to just leave it off to get to the filter from the top...however I guess since I have to pull that shroud under the bottom of the car to change the oil anyhow it does not matter much. The engine does seem to move around a lot with it on so its probably best to leave it that way...just curious about it.
Thanks
