Wheel bearing replacement failure.
I had planned on replacing a noisy left rear wheel bearing today. I did some research to ensure I had all of the right tools to make it an easy job before beginning. Apparently, I did not do enough research.
I removed the wheel, set the parking brake, and went after the axle nut. The first lesson I learned today is that a Harbor Freight 1/2" drive torque wrench is no match for that nut. I also learned that a long breaker bar would bend significantly with no movement of that nut, even with me standing on an end or using a trolly jack on the end. Then I learned that the Harbor Freight 20% off coupon that I had could be applied to the purchase of their electric impact wrench. After I got home, I removed the nut using the impact wrench (which still took more time than I would have expected,) and tried to attach the Harbor Freight slide hammer to the hub. It didn't attach, as the spacing of the holes on the hub remover attachment is too far apart for 4-100mm bolt spacing.
Thus, the car was reassembled without a bearing replacement. I will update this thread as the saga continues. Hopefully, others will learn what NOT to do from this thread.
