FS: NA/NB Soft Tops!!
I have three complete glass window softops (on frame) for sale, and the pricing includes installation using your existing latches and nuts/bolts, using NB frames that will properly support the rear window. If you do not have the latches and/or nuts/bolts, I can get them for a small additional cost.
1- Light Tan/Parchment OEM (glass window w/def) softop from a 2000 SE, 8.5/10 condition. $300
2- Black OEM NB softop (glass window w/def and tint), back window has been resealed - 7.5/10 condition. $250
3 - Dark Tan aftermarket softop (glass window) that is basically new, just installed on NB frame. 9.5/10 condition $275
I'll try to get some pictures this weekend, but you should plan to come look at the top if you have concerns about small cosmetic marks. I tend to evaluate a top based on overall condition, cleanliness and functionality. If you need a perfect top, then NIB is the only sure bet. #3 is very close to that, but is not brand new.
Installation to be done at my garage unless otherwise agreed to. A small discount will be offered if your existing NB frame is not wanted. I do not need any NA frames, unfortunately.
Is the dark tan fixed glass or zip-out?
Fixed. All are NB style fixed windows. The Dark Tan does not have the oem type separate flap, it is a one-piece top.
Does a one-piece top work with a roll bar? I thought you had to have a factory style top with a roll bar.
It folds the same as the others. If an oem glass window top will clear the roll bar, so will the one-piece. The key is determining which roll bar you have and whether it will work in an NB.
I'm just wondering what are you charging just for the tops without your installation. I'm only interested in the factory tops you've listed.
I don't need one installed, just the top. I've done my share of them in the past and don't mind doing this project myself?
I'd knock $30 off if you want to do it yourself. I mainly include the install since most people aren't sure what all is involved in doing it.
Sale pending on both tan tops. Will update when sold.
