Parts left over from motor and transmission swap
OK I've got a few items I need to clear out now that I no longer need them. All prices are OBO.
Parts For Sale
NA 5 speed Transmission w/ around 90k miles, $375.00, Completely Rebuilt shifter, New lower shift boot, All new seals ready to swap in
Stainless Clutch Line, Sold
1.8 ACT HD Clutch and PP, $old, w/ about 20k on clutch disk, Includes clutch switch over-ride and alignment tool
1.8 Oil Pan, $old, Has fitting for turbo oil return line
RC 550 Fuel Injectors, $100.00, Includes resistors since they are low impedance
Link ECU (1996-97) Obwain, $100.00, Includes: ECU, MAP sensor, air temp sensor, Keypad, interface cable and adapter, installation & tuning manuals.
Link ECU Master & Slave Chips, $75.00, These are the most recent chips available
Outer tie rod, $15.00, New but was used for a week or so while I was waiting on a new LE tie rod
Spin on 4 port adapter, $10.00, Perma Cool 2796 20x1.5mm threads
Remote Filter Mount 4 port, $15.00, Perma Cool 1791 3/4"-16 threads
Tru-Cool LB7 Oil Cooler, $25.00, 5.75x11x1-1/2 24 plate
OEM Fuel Pump $10.00, 90kmiles
1995+ turbo oil feed line, $old - New
FM Hard Turbo Oil Drain Line, $45.00 - New
99 OEM Valves and Springs, $20.00
Flyin Miata Stage 2 Cooling Fan Kit (older kit w/o shroud), $100. Everything needed for 1.8 cars, 1.6 cars will need to make some wiring changes
There may be more things I find and will add them as I do.
