Has anyone installed a grant steering wheel with grant hub on an NB? I have seen all kinds of write ups for NA. Issue I am seeing is when I tighten bolt the hub pushes down on the clock spring and then the wheel is hard to turn and the where the yellow sticker is on the ring gets torn up from rubbing. With the stock wheel there is no issue as the hub only goes in the middle and doesn't lay on too of the clock spring. Any help would be appreciated!
