Leaky pinion seal - NC w/LSD
Hey.
My '08 GT has been marking it's spot lately. I changed the gear oil in February (60k) and when I checked it last night it took 10oz to top it off. As I understand it, the level can be up to 1/2 inch below the fill hole, so I'm not terribly worried right now. I put in 75-90 Mobil 1 LS so maybe that has something to do with it.
I cleaned everything off and took it for a spirited drive. When I checked it again, the drain and fill plugs were dry but the aluminum rail right under where the driveshaft and diff meet was wet. The drive axle seals were dry too.
I called the dealership and not only do they want an arm and a leg to fix it, they want the other arm and leg too. I looked it up in the service manual and it's procedure has you pull out the diff and completely disassemble it just to replace the seal. Ouch.
I've heard rumors that it can be changed with the diff still on the car. Can anyone confirm or deny?
Who's the local go-to guy for this sort of thing? If it came to it, I could pull the diff, but I wouldn't trust myself cracking it open.
Thanks in advance,
Rob
'08 Dark Blue Mica GT
