Anyone have an oem 1.6 steering wheel & airbag assembly laying around that you could weigh? Need info for a proposed rule and it would save me the time of pulling mine off.
Thanks
Thanks
I have another wheel, but no airbag.
I should have that….hang on a sec.
Wow, 8.5 lbs ::Drive2::
I wonder how easy it will be to find a suitable 8.5 lb aftermarket wheel?
Adhesive tire weights....attached to the adapter. Along with the weight of it/bolts and the quick release flange should not pose a problem making the number. Heck we give up 300# or so to the crx
So the rule change passed? You can swap wheels, but it has to weigh the same as OEM?
No it is still under consideration. It was looking promising and then some started griping about weight.
^Ridiculous! I propose all drivers in my class have to weigh as much as I do....fair is fair! :punchout:
Thats easy old man……...
http://i84.photobucket.com/albums/k1...Smokelabel.gif
this is what I have on my track car
http://www.amazon.com/Tekniq-Snap-Of.../dp/B006R1X4VS
allows use of horn and Amazon says shipping weight of 2#
and I have their steering wheel too but don't find that available on the web
the adapter fits a 6 bolt 70mm wheel so should be too hard to find one
but weight won't be anywhere near 8.5#
