any six footer with a roll bar and helmet clearance?
I know there are, figuratively, a million threads on roll bars and clearance. However, I think it'd help to see it in person.
I have an NA with a Kirkey sitting on the floor (it does have around an inch of padding so I could get a little lower). With a hardtop, putting the bar as high and far back as possible would put the bar directly overhead which seems far from ideal. This is 2-3 inches in front of the back glass, rearward of this the top slopes down pretty quickly which would make the bar too low. The seat back is more or less lined up with the front edge of the back glass. So, even if I do remove the seat padding, the bar will still be directly overhead. To avoid that I'd have to move the bar back which would put it directly under the glass, and too low. I could move the seat forward a bunch but I'd rather not be that uncomfortable. The seat does have a modest amount of 'layback' which helps in dealing with an old back injury. I'm not sure I could stand it up enough to make a difference anyway.
I can't see how this will work and still have a top, that's why I'm hoping someone here has something that works that can be copied. Anyone have such a setup I could check out? I'm planning on going the custom roll bar route, but I'd be happy to see any solution, off the shelf or otherwise.
