15x9 TRMotorsport C3M Black with 225/45-15 Rival tires mounted (older version). Fairly worn and one has flat spot to cords, but I will include another tire to replace it. Still has some life though.
$400 picked up
$400 picked up
$360 picked up as is.
Still have these.
Still have these and a set that are grey with rs3 tires ($500).
What condition are the rs3 tires in? Also will these fit a NA?
Also fairly worn. No clue.
Fairly sure you'll need to roll the fenders to get 9's under an NA, but it's possible.
They will "fit" under an NA, but you will definitely need to roll fenders significantly and dial-in some neg camber. Even then, they will still rub on bigger bumps, hard cornering (spring rates/sway bars impact this), and when you have a lot of steering angle. Also, you'll need to be careful about the rubber you run, as the performance tires on the market often run wider than all-season tires in the same size. 225 is about the only good size option commonly available, unless you are looking for some kind of goofy-ass stretch look. In that case, you are forbidden from buying these track-capable wheels. ;)
Bottom dollar on a set with no tires?
