FS: TDR Intercooler setup for SC
I've decided I will not be going FI on the track build, so I'm going to let the TDR intercooler setup go. This is a complete used setup in good condition, and includes the ducting panels for the bumper opening to effectively direct the airflow. Also includes all of the couplers and piping, mounts, etc. This was previously installed on Titus' 1.6 M45 car, but can be used for numerous other SC/turbo combos with minor changes to tubing/couplers.
The TDR intercooler design is well-documented to be significantly more effective at reducing charge temps than the cheaper ebay intercoolers, and also being much better-built. This is definitely a case of "getting what you pay for," as chinese IC's are failure/leak prone.
I will include all of the mounting hardware, ducting/piping/couplers/clamps/etc. that I have, which should provide a complete install for M45 superchargers, and I believe for MP62 also. (Need to confirm with TDR).
I also have some high-flow injectors and a complete Link ECU kit with knock sensor that I can bundle with this, if you're looking to take advantage of the IC for more power.
Sold.
