Parting a 1990 Miata in Red, motor already gone. Car is in great shape, no rust, no wrecks, paint is so-so. Roller chassis (stripped) with clean TX title in my name available for the next few days. If interested, it's $100.
I'm not posting pics of every item. If you have a specific request, send a message and I'll describe it and/or shoot a pic.
Some of the things I can verify are available are:
-Red headlight "barn doors." Left is perfect, Right is a little beat up but save-able. $20/each
-Rear Red bumper cover, in good condition. $50
-Headlight assemblies with motors and bulbs. $30/each
-Black NA drivers door. Window glass and power regulator/motor removed, wing window and latches included. Sheet metal is in great shape. Couple of small dings. $50
-1990 black dash with NO CRACKS, great condition. Also have good tombstone. Can be sold with or without. Already removed from car. $100 dash / $50 tombstone or $130 for all of it.
-5-speed transmission in good condition w/clutch - $150
-Black manual window door cards and padded uppers, armrests. $25/ea
-All interior plastics in black. Side panels are cut for HT striker plates. $50
-Black softtop on frame with good repaired rain rail and plastic window. Window is in great shape, quite clear. Zipper is broken and has been sewed shut. Top is older, but doesn't leak and raises/lowers fine. Weatherstripping is good. Latches and strikers also available. $150
-Center console with leather shift boot. $20
-Set of 14" oem steelies with center caps and decent tires. Rear tires are taller than front. Meh. 2 silver, 2 black. $100
-PPF, 1.6 open diff, axles, stub axles, uprights, etc. I'll give the entire rear subframe with all this stuff attached if desired for the same price as removed. Maybe cheaper. $75 for entire subframe, or just take what you need.
-1.6 drive shaft, good u-joints. $50
-Complete unmolested 1990 wiring harness. Only damage is one of the side marker connectors (pass). Otherwise all-original. Removed from car and boxed up. $100
-Set of excellent condition daisy's, OEM silver paint still nice. $150
-Airbox, HVAC controls, AC compressor, condenser, interior dash components, etc. Complete system available, or parts. Worked prior to removal. R12, unconverted. (pending)
-OEM clear front turn signal lights (glass) $50/pair or $30 each
There is bound to be more stuff, just ask.
