Does anyone have one that I can borrow? Next week I'll be putting the racer back together and would like to get something to refer to that has better torque values than the Haynes book.
I have a crapload of new parts here & on order (be here Thursday!) to put back on the car...
Head bolts & washers, intake & exhaust studs, valve cover baffles & screws, head gasket kit with intake/exhaust gaskets & lots of extra seals, cam seals, crank seal, woodruff key, crank bolt, timing belt, water pump, cas o-ring, plugs, (new wires were included with the car), thermostat & gasket, radiator cap, valve cover gasket, and antifreeze.
I guess I should also get a PCV valve for good measure... and I'll be inspecting the hoses, crank gear, and probably replacing the belts too...
Can ya think of anything I'm missing? ;)
