Driving down the road a few weeks ago, my upper radiator hose burst. I didn't notice it until the check engine light illuminated. By that time, the temp gauge was pegged. I got a tow home, replaced the upper hose, refilled the coolant, and started trying to get to work again. It made it about 5 miles before the temp gauge pegged again. I refilled the coolant, and started heading back home. I had to stop a few times on the way home to buy a couple of gallons of water to refill the coolant when the temp gauge started climbing.
After this abuse, I figure I have a warped head and bad head gasket at minimum with an unknown probability of a warped block. Knowing this repair would take a while if we went that route, and thinking we would probably sell the MIata as is, we bought a 2002 Mustang instead of getting a rental and repairing the Miata.
After seeing the cost difference between the Mustang and the Miata, the wife is wanting me to repair the Miata in my spare time and eventually sell the Mustang. I am leaning toward just getting a junkyard motor, but that hasn't worked too well in the past. On the other hand, a rebuild would be too costly, and I don't know enough to know whether it would be a good idea to just pull the head and take the head (or head and block) to a machine shop to be machined flat.
If anyone has knowledge in these areas worth sharing, I would appreciate it.
Thanks.
