I've been chasing an annoying rattle in the right rear of my 2002 Vivid for months. I've tightened everything in sight, banged on most everything, and zip-tied some wiring harnesses just to be sure. I still couldn't find it until tonight. I *think* it's my rear brake caliper assembly. If I grab the brake hose and move it, I can get the floating portion of the caliper to rock back and forth. Also, the rock shield behind the rotor sounds similar to the rattle if I bang on it. No bolts are loose, but there is play in the floating portion of the brake assembly. I don't actually need new rear pads, but they are old, perhaps original (~110k miles). I suppose if I replaced them, there would be more friction material taking up space so there might not be as much play.
Has anybody run across this before? Any other things I might have overlooked in that assembly?
