Overheat Solution!!!  Maybe.
		OK, I have a little solution for the summertime over heat problems.
You can jump the TFA and GND wires in the DIAGNOSTIC control.  This will make the fans come on when the key enters the ON position and keep them on regardless of temperature.
I already have my fans wired in parallel so essentially both fans will be running all the time. When then outside temps come down you can take the jumper wire out.  I use 20 Guage SOLID core wire to perform the jump available at Radioshack because it holds it shape and has shielding.
I will give you a road report over the next week to confirm any drop in temps.
I am currently running 104 to 108 degrees celcius in stop and go traffic - my fans usually come on at 100 degrees celcius.  I am hoping that if I can prevent the radiator core from becoming heat soaked, I can stay ahead of the cooling problem.
If this doesn't work, I am punching two holes in the hood and venting using cheap vents.
I believe the root cause of my problem is the unshielded turbo and downpipe.
Hey, and somebody throw me some Karma (Spectacular Aura) points, I'm running low.
