Miata's off the road this week... :cry:
Last night, drove to Kroger for some bread, thought something didn't feel right. At Kroger, took a quick look round to see a puddle of coolant coming from under the car... It stopped dripping pretty quickly, and hasn't leaked in the garage, but I still don't want to drive the car with coolant leaking.
It seems to be coming from the rear of the engine, and the CAS seal is leaking, so I'm adding two and two and getting the heater hose. So a new set of hoses (may as well replace the lot, bottom radiator hose is pretty old) is going to be on order. Bye bye $75.
What's even better is I put the car up on ramps and dropped the splash guard, to find that the steering gear, the bottom of the oil sump, and the AC pump are all covered in oil. aaarrgghh One of the wire loops fastening the gaiter onto the steering is broken... All must have happened recently, wasn't bad the last time. Would the loss of the wire loop mean the steering gear could be leaking - or am I going to have to strip the front of the engine down to find leaking oil seals?
I was to have had new tires, had wifely agreement and everything. Instead, looks like I'll be buying parts again...
(This car does seem to need lots and lots of replacement parts, and constant attention. Not good.) :-(
