Last weekend i bought a can of Sea Foam which is really good to clean your vacum lines, on my old car i would disconnect a vacum line and turn my engine on so that pressure would suck the liquid into the engine, turn the car of for about 5 minutes, and start it up and take it for a smoky ride. That thing works imidiately and you can see the trail of smoke as you drive it of. Anyway i tried this on my Miata and it triggered three codes for my check engine light (CEL). It cause high circuits in the IAT sensor, spark plug misfire, and mass air temperature... This happened when i turned on the car with the vacumm disconnected.
I unplugged my battery for about a minute and plugged it back, the codes were gone and the car runs better. I poured the other half of the can straight into my gas tank and the car runs smoother now.
Anyone ever used Sea Foam on the oil tank? I wanted to do this but i gotta be sure it won't cause any problems. The instructions said it could go in your gas tank, oil tank, and vacumm... my best bet would be to use it about a week before i do my oil change...
any inputs on this product?
